01-08-2025 06:11 AM - edited 01-08-2025 06:12 AM
My heatlink is not connecting to the thermostat and has no lights on so unable to use the heating. I have run through the standard troubleshoot online with no luck.
The thermostat is close to the unit, nothing is blocking the signal and plugged in so this is not an issue. It displaying warning H71.
I have tried turning off and on the boiler, the mains switch and the router. None of which have made a difference.
01-11-2025 12:43 PM
Hi, @Charlielcooke!
Thank you for reaching out to the community. I apologize to hear the Heat Link is not connecting to the thermostat, and it’s not giving any light. I know how important a reliable heating system is, especially during winter. I’d be happy to help you!
I appreciate you taking the time to turn off and on the boiler. To gather all the necessary information and provide you with the best assistance, please answer the following questions:
In the meantime, please ensure the following:
Additionally, if the steps above don’t work, please reset the Heat Link to default settings and restart the network on the display; after that, try to set up both devices again.
Thank you for your cooperation. I look forward to your response.
Ana
