02-07-2024 10:06 PM
I need to automate a kasa smart plug (hvac in line fan plugged into that) turning on somehow when The nest (air conditioning) turns and when the nest (fan only on ac) turns on
How can I accomplish this? Google automate?
Or IFTTT?
I did see IFTTT had an applet with nest fan/wemo plug but not for mine…here it is https://ift.tt/wf8Ng4H
But it tells me there’s gotta be a script or coder some way to do it. I just need it in simple language
plz and thanks
02-08-2024 12:45 AM
Example:
metadata:
name: Cool weather heating
description: If it is cool, open blinds, turn on fans, and adjust thermostats.
automations:
- starters:
- type: device.state.TemperatureSetting
state: thermostatTemperatureAmbient
device: thermostat - Family Room
lessThan: 18C
actions:
- type: device.command.OpenClose
devices:
- blinds - Bedroom
openPercent: 100
- type: device.command.OnOff
devices: fan - Bedroom
on: true
- type: device.command.ThermostatTemperatureSetpoint
devices:
- thermostat - Family Room
thermostatTemperatureSetpoint: 21C
02-08-2024 01:16 AM
That doesn’t help respectfully-
I only want the smart plug to turn on when the nest turns on the air conditioner
02-08-2024 03:21 AM
Do you use the Google Home App or the Google Home web page?
02-08-2024 05:23 AM
I could use either
02-08-2024 07:30 AM
OK. I use the Google Home App on my Smartphone to see my Home and all the Devices. There you can Edit simple automations too. If you wont writing scripts you have to go to the Google Home web page.
12-15-2024 09:04 AM - edited 12-15-2024 09:04 AM
I have the same question - want to power on a whole home scent diffuser connected to my hvac but only when hvac (via Nest thermostat) is on
05-22-2025 11:50 AM
I’m trying to do the same thing. Did you ever figure this out?
Wednesday
Google Home allows it but only through Script Coder in the desktop version. Phone app will not allow it. I wanted to turn on and off my HVAC scent diffuser when the HVAC was running / not running and achieved it using the following code. This is the code for turning the outlet ON:
metadata: name: Turn on Diffuser when the temperature rises above 77.9. description: Turn on Diffuser when the temperature rises above 77.9. automations: - starters: - type: device.state.TemperatureSetting device: Downstairs - Downstairs state: thermostatTemperatureAmbient greaterThan: 77.9F actions: - type: device.command.OnOff devices: - Smart Plug Scent Diffuser - AC Cabinet on: true
