Weather related routine
AndreCape
Hello Google team,
To control shutters, shades and lights it would be helpful to have weather related routines like.
Sun - close blinds 50%
Cloudy - turn on several lights
Rain - shutters down, lights on
Wind -  shutters down
Is there anything on the market at this moment or how can I realize it. Normally a connection to a local weather station would do it I guess.
Regards and thanks in advance,
Andre
2 REPLIES 2
OpethNJ
Assuming you have compatible hardware you can do this in a pretty easy way from the Google Home Script Editor.
This link takes you to the examples section for the Script Editor documentation , Specifically, it takes you to the example of:
Abbys_Dad
The starter you reference is only triggered by Google internal home sensors such as Google Nest Thermostat.  Andre is asking for environmental event data that is outside the home which is not currently supported by Google Home. While Tempest and Ambient weather stations communicate with Google Home (you can ask Google to tell you that current temperature), this is very basic integration in that it doesn't support triggers from those data sources (as IFTTT and HA can).
