01-17-2024 12:40 PM
For years I have been using my Nest Wifi point with the built-in Home speaker to play white noise overnight for my three-year-old. The command "hey google, play white noise" usually triggers the Relaxing Sounds white noise that loops hourly for 12 hours. Over the past few weeks it's been stopping at seemingly random times overnight, waking him up, and I can't figure out why. Has anyone else experienced this? Is there an automation/routine that will ensure it doesn't stop playing? We need sleep 😩
01-21-2024 10:23 AM
Hi sam3K,
That certainly isn’t the experience we want you, and we apologize for the delay. We understand your concern and the importance of reliable white noise for your toddler's sleep.
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
Hope this helps.
Dan
01-24-2024 09:33 PM
Same here and this wakes our 9-month old randomly too at night.
So annoying. Still broken as of today.
02-04-2024 05:34 PM
Hi febzz,
We're sorry to hear that you're still experiencing this kind of concern. Just so we are on the same page, have you tried the steps above? If so, how was it? What device are we working with?
Dan
02-04-2024 05:39 PM - edited 02-04-2024 05:40 PM
Yes all of the above options have been exhausted/tried but to no avail.
Best workaround for me: I had to create scheduled automation routines to start White Noise at different times between midnight and 6am in case the first White Noise started between 7 and 8pm prior night somehow stops playing overnight.
This was never an issue before and White Noise used to play for 12 hours straight, so if I started it at 7pm, it would end around 7am. No longer the case, as of around 3 weeks ago.
02-04-2024 05:58 PM
Hello there febzz,
Could you be specific with the device that you're using? Is it a Google Home speaker or a Nest Wifi point?
Dan
02-04-2024 06:15 PM
Hi it's a Google Nest Mini (2nd gen) as opposed to Google Home Mini (1st gen)
