Help with motiondetectionevent eventdata
jameskpenn
Maybe I am making this harder than it needs to be but I am trying to setup an automation that turns off my exterior lights if either my Hue motion sensor or nest doorball does not detect motion for at least 10 minutes.
I have the hue motion sensor figured out via the motion detection state.  I am not able to figure out how to check the eventdata for motiondetectionevent for the last motion trigger and check if it is over 10 minutes.
The doorbell does not support motiondetection STATE so I have to use event.
Any suggestions?
Pitsom
Something like this?
- starters:
  - type: device.state.MotionDetection
    device: sensor - Living Room
    state: motionDetectionEventInProgress
    is: false
    for: 5min
  actions:
  - type: device.command.OnOff
    devices:
    - light - Living Room
    on: false
