Help with the toshiba 55L421U
Shak2
So basically my toshiba 55L421U was owned by someone else and now they gifted it to me but the problem is that its on a blue screen with a code and I already tried to get it hooked up to wifi but I have no remote so is their a way to disconnect it from the buttons so I could connect it.
BeulaA
Hi @Shak2,
Thank you for reaching out to the community. I understand that you would like to switch your TV to a different network, but you don’t have the remote and are trying to connect it without using the TV buttons. I know how important it is to have your devices working properly, and I'll be glad to share more details with you.
For help with your specific TV model, please reach out to Toshiba TV Support they can provide the most accurate information for your device and its connection options.
Hope this information helps.
Beula
