11-02-2025 08:45 AM
My living room Google Nest four lights flash after this automation runs, daily. How can it be fixed?
11-02-2025 08:46 AM
Nest not next
11-02-2025 08:50 AM
Google home nest's four lights flash after running this automation daily. How can it be fixed?
11-05-2025 02:31 PM
Hi @Emmettx,
Thanks for posting in the community. I understand that your Nest Speaker shows four flashing lights daily after an automation runs. I appreciate the information you've shared so far. No worries, let's work together to get this resolved. To help with that, I have a few questions for you:
Any additional details you can provide will be helpful.
Jonathan
11-09-2025
03:49 AM
- last edited on
11-09-2025
10:04 AM
by
sicsacol
I'm not sure what type it is. The order states ##############. Nest Audio Chalk. Four little white lights behind the speaker gauze. The automation is to turn on and off all 6 living room lights together, without having to have a separate one for each light. After it runs these four lights behind the gauze flash interminably. Why? What is wrong with it?
11-09-2025 02:34 PM
Hi @Emmettx,
Thanks for your update and for the additional information you shared. The flashing lights usually mean your Nest speaker is in the middle of completing a command, like your automation. To help me figure out what's happening, while the four lights are flashing, does your Nest Audio complete the automation (do the living room lights turn on and off)? Also, you may want to check out the following article to learn about the LED lights on your speaker.
Please keep me posted.
Jonathan
11-10-2025 11:30 AM
Yes the automation works, but after the units four lights remain flashing all evening.
12-02-2025 02:06 AM
This just started happening to mine as well
01-16-2026 09:33 AM
I've had this same issue for months with a similar automation for turning off all of the lights.
02-01-2026 08:50 AM
I also have the same issue for weeks now.
02-12-2026 09:57 PM
I've had this issue ever since the "upgrade" from Google Assistant to Gemini. The automation runs just fine, but the speaker continues to flash the lights as if it's continuing to be doing work. Happens with all my routines, indulging of I delete and remake them. Only way to get it to stop is to say "hey Google... Nevermind" too break it out of whatever loop it was in and get it to complete another task. PLEASE HELP! This is incredibly annoying!
02-23-2026 08:19 PM
having the same issue here!
02-27-2026 10:34 PM
Experiencing the same issue......no official response/fix from google when the original post is from last Nov?
