10-29-2025 05:21 AM
Hi there
From Google Home app, I'm trying to create an automation based on the "Home/Away" trigger.
As far as I understood, the trigger comes from my Nest protect.
In Google Home Activity, I can see that the system detects when I'm away/AT home (see screen capture).
But when I try to create an automation, whatever the action is, it says that the trigger needs an additional configuration but I have no Idea which one (documentation does not help).
See screen capture.
Any help would be appreciated !
11-02-2025 05:43 PM
Hi Simon79,
Thanks for posting. I understand that you are having some issues while you are trying to set up your Home/Away routine, and it is asking you for additional configuration. Don't worry; help is here. I just need to ask for some information to provide the best solution:
Jenny
11-03-2025 01:24 AM
Hello Jenny,
The Home/Away is setup with a Nest Protect (détecteur de fumée).
I tried several things including, removing the app, clear cache,...
Unfortunately, I cannot attach pictures, but what I see in automation is just a basic "Error(s)" message displayed below the "Home" routine in Google Home.
When I click in the automations, in the "Home" trigger I have an alert message saying that "The trigger needs additionnal configuration" but that's all.
Any help is appreciated !
11-05-2025 04:45 PM
Hi Simon79,
Thanks for your response and the information provided. I need you to confirm some information for further investigation:
Please keep me posted.
Jenny
11-16-2025 02:19 AM
Hello Tajennifer
Thanks for your answer.
Here are some answers :
- What type of automation did you create, personal or household?
I'm not sure to understand your question. Can you clarify ?
- Have you granted Google Home permission to access your device location?
Yes for sure.
- Have you enabled “Allow this device to report your location” in the Google Home app settings?
I don't have this option in the Google Home settings. I have version 4.2.51.1
- Have you enabled the presence sensing in the Google Home app settings?
- What type of automation are you trying to create (e.g., lights on when home, thermostat off when away)?
Basic stuff: "Say what Time is it". I didn't set complexe automations as the Home/Away trigger is not working at all.
- Have you tried deleting and recreating the automation?
Several times, from several devices. I also tried to delete app, clear cache,...
- What type of phone are you using (Android/iPhone, model, OS version)?
Google Pixel 8 Pro with latest Android version.
On internet, lot of people have the same issue. It seems that we can fix it by creating the routine from a device that never had Google Home installed. But unfortunately I don't have other devices.
11-16-2025 02:21 AM
Unfortunately we are a lot in this situation. This seems to be a well known bug in Google Home. But I struggle to find a work around solution. Maybe with another app ?
