11-19-2022 04:12 PM
Hello all,
this is my wire configuration in my old Honeywell thermostat. How I am supposed ti connect the A B wires?
Thank you
12-01-2022 12:53 PM
Hello natopigro,
Thanks for reaching out to the Google Nest Community Forum. I'd love to help.
It appears that you have Proprietary system, which are designed by the manufacturer so that they can’t work with other thermostats. But some proprietary systems may also have the option of using standard heating system wires. Contact a Nest Pro to see if your proprietary system can be rewired to work with Nest.
Please let us know if you have more questions.
12-05-2022 03:25 AM
12-06-2022 09:18 AM
Mel
