11-25-2022 04:34 PM
I was needing some assistance to see if this is compatible? I tried using the link here but I couldn’t figure out if the RH/B and the RC/O is or not. I don’t know much about these units so any help would be great. Thanks
11-29-2022 11:15 AM
Sorry to hear about the trouble. I wanted to follow up and see if I could be of any help. Taking a closer look at the picture, you will want to remove the jumper wire, as Nest Thermostats are not compatible with jumper wires. Just to confirm, that would you with G, W, Y, RH correct? If so, I am showing you are compatible. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
11-29-2022 02:03 PM
I think it’s RH. It read RH/B and RC/O. That’s what was confusing me was the two on the end. I appreciate your reply
11-30-2022 11:39 AM
12-04-2022 02:59 PM
Hello Rt78,
I know it has been a while, but I wanted to ensure that everything is covered here. Still need our help? Let us know so we can assist you right away.
12-06-2022 05:27 AM - edited 12-06-2022 05:27 AM
Hi Rt78,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
