Lancer radio sur autre hp Google nest ne marche plus
Patou13Fr
J'ai 3 haut parleur google home nest
avant:
quand je disais à un Google Nest (chambre), met la radio sur un autre Google nest (salon) cela fonctionnait
aujourd'hui, il n'y a pas d'erreur mais ca ne marche pas
Rusell
Hi Patou13Fr,
Thank you for posting in the community. I understand that when you told one Google Nest device (the one in your bedroom) to play the radio on another (the one in your living room), it worked as expected. Now, this isn't working. Help is here!
To help me find the best solution, I'll need to ask you a few questions:
  • What kind of Google Nest speaker or display do you have?
  • Have you tried any troubleshooting steps so far?
  • Is this happening with all radio stations or only specific ones?
Keep me posted.
Rusell.
Patou13Fr
Bonjour
We have two google nest mini.
I have tried many different keyword but it doesn't work
best regards
Rusell
Hi Patou13Fr,
Thank you for your response. Here are some troubleshooting steps that I'd like you to follow:
  • Unlink and link radio station:
    • Open the Google Home app Google Home app
    • Tap the account.
    • Tap Settings.
    • Under Services, tap Radio.
    • Choose a radio service, then tap Ok.
    • To unlink an account, tap Unlink account. Note: Please follow the same steps to re-link your radio station.
Additionally, I'd like to know:
  • Does the command work for requesting a radio station on only one Nest Mini?
Keep me updated.
Rusell.
