09-15-2022 06:27 AM
Every time I have a power outage, typically brief, when the power returns Google Home automatically turns on all lights including 3 in my bedroom. I would like to obviously find a way to correct that. Is it possible?
09-20-2022 10:57 PM
Hi DJBobbyG,
Thanks for posting.
By default, light switches are always turned on. You only turn it off by using commands or by controlling the app. In any case that you don't want it to happen every time that you will encounter power outage, you will need to turn it of on its switch manually but will not be able to control using your voice or the app.
Hope this answer helped. Let us know if you have other questions and the community would gladly answer it for you.
Princess
09-23-2022 11:07 PM
Princess
09-26-2022 02:49 PM
Hello there,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Princess
