Lutron Lights Offline, Can't Unlink and Relink
natelaw33N
Hello everyone.
All of my Lutron Casita lights have gone "Offline" in my Google Home app.  All of the lights work perfectly when accessing them Lutron app.  I've tried "unlinking" Lutron and "relinking" Lutron in Google Home but the link to Lutron never shows up in "Linked Services."  I've deleted the Home app, reinstalled, deleted my Home in Google Home and tried moving the lights around, I've cleared caches in Google Home, Assistant, and Lutron--nothing seems to work.  If I could just delete the lights from Google Home, that might do it--but I can't get rid of the lights even though I am unlinked in both Google Home and Lutron apps.
Same issue with my August home--it is not linked in Google Home, but the lock is still showing as offline in Google Home.
Thanks for the help!
6 REPLIES 6
Azarco
Hey natelaw33,
Thanks for reaching out and sorry for the trouble this has caused you. Have you recently made any adjustments to your WiFi network, Google Home and/or Lutron setup? Also, try using a different phone in linking your Lutron account.
Keep me posted!
Kind regards,
Alex
natelaw33N
Hello thanks for the response. Yes I changed my wifi password as part of a hard reset.  since then, I can't get google to link with Lutron. have rest the lutron hub as well but to no avail.  my Google home just shows all of the lights as offline, it's like Google needs to clear the cache but can't. when I try to link lutron it says "successful" but the link does not persist in the linked apps menu.
natelaw33N
I will add that I have set up a new Google home under a different Google account and there is no issue with lights being offline in the Google account--clearly a Google home glitch. my original account still will not recognize the lights.
Azarco
Hey natelaw33,
Apologize for the late response.
Give these steps a try:
  1. Reboot your Google Home, Lutron lights and router to refresh the connection.
  2. Uninstall and reinstall your Google Home app.
  3. Log out from your Lutron app and sign back in.
  4. Reset your Google Home.
Hope that helps.
Alex
Azarco
Hey natelaw33,
I'm just checking in to see if the troubleshooting steps shared help? Let us know by updating this thread, and the community will be happy to lend a hand.
Alex
Azarco
Hey natelaw33,
Bumping in to make sure that you saw our responses. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Kind regards,
Alex
