07-31-2025 02:04 AM
For the last 2 months or so I have noticed that my set up automations work as they should however voice commands.... that is a whole different story
For example, if I ask google home display to close the blinds, it confirms the command unyet does nothing. It is the same with my Samsung 8K 2024 TV and various other devices....
I completely switched over from Amazon alexa to the Google platform and am now beginning to question that decision
07-31-2025 04:04 AM - edited 07-31-2025 04:07 AM
Reconnecting the app in the Google Home app...Settings ... Works with Google is the same as disable - enable the Skill in Alexa.
I use both Alexa and Google simultaneously as there are advantages and disadvantages to both systems. And if one fails to do something I can turn to the other to pick up the slack.
08-03-2025 11:34 AM
I'm not sure why, but I had a similar problems when trying to change colors on multiple lights in one room. My solution was to rewrite the routine to change them individually. Good luck.
