01-14-2023 01:09 PM
I have 2 Hue motion sensors for starting a household routine, this works without problems...
But when I set the routine to start at a specific time/day, nothing happens. There are 3 options: At sunrise, at sunset or between 2 times... non of them works.
All my other scheduled routines works just fine.
Has anyone else the same problem??
01-18-2023 11:35 AM
Problem solved:
I did play around with the timer and it seems that the timezone on the app is different than mine, there is a difference of 6 hours.
So if I want the routine to start at 9 pm, the time must be set at 3 pm on the app.
Currently it's not possible to change the timezone, hopefully this will be added in the future.
04-05-2023 06:21 PM
Hi Kidibul,
As we got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we won't hear back from you in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Kind regards,
Dan
