Move to new home camera is still reading offline
Cadd
Recently moved and had to unplug all my cameras in new house cameras plugged back in green light on camera still not showing up in app same camera is offline how to fix
2 REPLIES 2
MetalGlacier
Product Expert Alumni
Nest Cams rely on a stable internet connection to stream video. Did you connect them to the new wifi at your home?
@Cadd
Are you using a new or different Wi-Fi router/modem in your new house? If so, did you set your network name (SSID) and password to the same values used at your old house?
If not, did you remove your cameras from the Google Nest app or Google Home app and do a factory reset before reinstalling them?
https://support.google.com/googlenest/answer/9223711
