Need help resetting on/off timer
Jules54
My 29 yr old son recently passed away and had my whole house set up on Google. I have Google speakers, Nest, Google plugs, lights, etc. I know how to access everything, but I don’t know the technical side of it, and how to run it. I tried to find information on how to reset the on/off timer he had set on a lamp in my living room. Everything is set up through our Google Home app. Can someone help me find where I can reset the time?
Thank you!
Juni
Hi Jules,
Thanks for reaching out. If you are referring to adjusting the time on routines for your lights, you can follow these steps:
  1. On your phone or tablet, open the Google Home app Google Home.
  2. On the Home screen, tap Routines .
  3. Select the Routine you want to edit.
  4. Edit your Routine:
    • To edit a starter or an action: Tap it.
    • To add a voice command starter: Tap Add starter and then When I say to my Assistant.
    • To add a non-voice command starter: Tap Add starter and then a non-voice starter.
    • To add an action: Tap Add action.
  5. At the bottom right, tap Save.
Check out this article for more information.
Juni
LovelyM
Hello Jules54,
I want to jump in to check if you tried the steps above. Don't hesitate to let us know if you still need our help.
Lovely
LovelyM
Hey Jules54,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. We'd be glad to help you further so if you still need assistance, feel free to start a new thread.
Lovely
