Nest Protect will not connect to WiFi if set to WAP2/WAP3
Tanquen
Nest Protect will not connect to WiFi D-Link DIR-882 router if set security to WAP2/WAP3.
So they do not support WAP2?
I have 4 of them all the same.
Model: Topaz 2.7
Software 3.4.1rc1
That is correct.
The Nest Protect does not support the newer WAP3 protocol, they also only support the 2.4 GHz band
Tanquen
But it's set to two and three, not just WAP3 and it's not connecting.
Hello folks,
I'm sorry for the late response. I wanted to stop by and see how I could help.
@Patrick_Caezza, thanks for giving assistance.
@Tanquen, In addition to the above, Nest Protects are only compatible with WPA2 Wi-Fi security on the 2.4 GHz channel. You can check these Nest Protect technical specifications and Update Wi-Fi network and router settings links for more details. Also, here's additional setup link.
Please let me know if that helps.
EmersonB
@Tanquen chiming in to see if you still need assistance with this. Hope the previous post helped.  Let us know if you have more questions in mind.
@Markjosephp and @Patrick_Caezza I appreciate your helpful response.
JenniferV
Hello Tanquen,
We haven't heard from you in a while so we’ll be locking this thread if there’s no update within 24 hours. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
Thanks for the help here, Patrick_Caezza, Mark, and Emerson.
Jennifer
