12-12-2022 10:28 AM
Is anyone else having problems with their NEST thermostat today? I cannot reconnect to my network. I have tried all troubleshooting including restarting the modem, resetting it to factory default, and restarting it. All other devices are connecting to my network with no problems.
12-12-2022 03:45 PM - edited 12-16-2022 03:53 PM
Turns out the thermostat needs to be replaced and Google will send a replacement as it is still under warranty. I really appreciate their customer service.
12-16-2022 01:47 PM
Hi VickiATL
We're sad to see you go. We hope we can make it up to you in the future. Send us a message if you change your mind.
To confirm, are you getting a message when trying to set it back up?
Mel
12-16-2022 03:29 PM
Hello Mel, The message is failed to connect. It is finding my network now. But when I try to connect to it, it consistently states failed to connect. I contacted customer support, we checked the power, and they explained that it is still under warranty and I qualify for a replacement. I am happy with this resolution. I will try Nest again since customer service has been so helpful.
12-16-2022 06:31 PM
Hi VickiATL,
Thanks for the update. I'm glad to hear that you were able to get a replacement. Let us know once you receive it. Keep us posted.
Edward
12-19-2022 06:37 PM
Hi VickiATL,
Edward
12-20-2022 06:39 PM
Hi VickiATL
Edward
12-20-2022 07:06 PM
No, I do not have any other questions or concerns. Thank you!
12-20-2022 07:31 PM
Hi VickiATL,
Thanks for the update! I will be locking this thread in 24 hours. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
