Nest Thermostat E not connecting to wifi even after a factory reset
Ohhman10
I have been trying everything, moving router, reseting wifi, restarting my nest, resetting it to factory settings etc. but I can not connect my nest to my wifi. It used to be connected until my circuit tripped.
Has anyone had this problem?
Thanks!
7 REPLIES 7
mtmra70
Same issue here. Error TD005.....
Ohhman10
Any luck?
mtmra70
Nothing. Joins wifi just fine via the thermostat itself. Just fails when trying to add via app 😞
mtmra70
Finally got it to work. I used a 3rd spare phone which never had the Nest app on it. Worked first try (thats the short story).
Hello folks,
I know it has been a while, but I wanted to ensure that everything was covered here.
@mtmra70, I appreciate you posting and updating us on your efforts to address your concern and find a fix. Let us know if you need more help.
@Ohhman10, how's it going? Have you managed to add your Nest Thermostat back to the Nest app? Please let me know if you are still having trouble from here, as I would be happy to take a closer look and assist you further.
Hi Ohhman10,
I'm checking back in — how's it going? Still need our help?
Juni
Juni
