Nest X Yale Lock
Kim13ber
    My customer has a Nest X Yale Lock. They want it installed, but just want to use it as keyless entry and do not want to connect it to their phone or the internet. Is this possible?
David_K
Yes, but it must be connected to Wifi and the internet first to complete the setup. Once setup, it can be disconnected from Wifi and will function offline. Most passcodes will still work, as will the thumb turn inside the home. Of course, features such as scheduled access and app notifications won't work as the lock is offline.
janthadeus
Hi Kim13ber,
Checking in — I just wanted to make sure if you’ve seen davidking’s response. Let me know if you need more help.
I appreciate your help, davidking!
Thanks.
janthadeus
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
janthadeus
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
