Nest doorbell notifications battery
SCam
I have just installed a nest battery doorbell. The android user in the house receives notifications on their phone but I don’t get them on my iPhone 13 Pro. I have checked everything is selected that should be but I can not get it to work.
I would appreciate some advice.
janthadeus
Hi SCam,
I’m sorry for the delay. No worries, we’ll sort this out — a few questions: is there a pending iOS update? Is there enough memory on your phone storage? Also, is the Do Not Disturb setting off and the Background app refresh on in your phone settings?
Going over the steps here might help:
  1. Restart your Nest camera.
    • Plug the camera into a power source.
    • Locate the reset button at the back of the camera.
    • Press and hold for 5 seconds.
    • Your camera will restart, and the status light will be steady, solid white.
  2. Restart your modem or router, unplug it from the power outlet for 1 to 2 minutes. Then, plug it back in.
  3. For iOS devices, go to Settings > Notifications > Nest or Google Home and follow the configuration below.
    • Allow notifications is enabled.
    • You may disable any or all notification options.
  4. Restart your phone. Turn it off for 60 seconds. Then, turn it back on.
Let me know how it goes.
janthadeus
It's me again. I want to make sure you're all good — did those steps work?
aatienza
Hello there,
I appreciate the help, JT.
Archie
