Nest mini not working
Katbunk
I have had a Google nest mini second generation for about two years now I hadn’t used it for about a year and a half and I just plugged it in so that I could play music but it won’t work. It says that it’s plugged in and everything, but there’s no audio coming out of it. If I put it on mute, it doesn’t say that the microphone is on mute. It doesn’t respond when I ask a questions and I don’t know what to do if anyone has any tips that would be greatly appreciated.
@Katbunk
Maybe you need to factory reset it and then reinstall it:
https://support.google.com/googlenest/answer/7073477
If you can see it in the Google Home app, you could try removing it first.
