12-21-2023 04:33 AM
I installed a Google nest learning thermostat earlier this year in my living room. It has been very inconsistent with heating and cooling our house. We have turned off all 'learning options' and set a daily schedule of when we want the system to turn on and off and what Temps we want. It won't follow the schedule. Coming downstairs in the winter and having it be 65 degrees when it is set to come on at 6am at 71 degrees is very frustrating. We have to turn the thermostat on and off to get it going or turn the heat up to some very high number 85+ degrees to come on. Working from home the Temps will drop to 68 degrees and it doesn't kick on despite being set for 71 all day. This is extreme frustrating. We have checked and double-checked all settings, it simply won't follow our schedule. Getting ready to replace this with one that will work!!! Any suggestions or similar experiences?
12-26-2023 06:55 AM
Hello Fjmundhenk,
I'm sorry to hear about the challenges you've been facing with your Nest Learning Thermostat. Inconsistent heating and cooling can indeed be frustrating. I appreciate you've already tried turning off the learning options and setting a daily schedule, but it's unfortunate that the thermostat isn't following the programmed settings as expected.
Here are a few suggestions that might help:
Let me know how it goes.
