Prevent a speaker from interacting with a smart plug or smart light in another room
TheSanjo
Hi
I have smart speakers in two rooms and in each room I have smart plugs which control lamps. I have discovered that a person in one room can switch off and on the lamp in the other room and I am looking at how I can prevent this. Ideally I would like the lights to be called lamps or lights in the rooms but for only the speaker in the room to control them. Is that possible?
David_K
There's no setting or feature to prevent that unfortunately. All devices connected to the same Wifi network can be controlled by a phone or tablet connected to that WIfi network. The only way you could prevent this, if your router supports this, is to create a separate Wifi network for each room. However, you'd then need to connect to the different Wifi networks to control the devices in those rooms.
I’d encourage you to also send this feedback directly to Google. You will not receive a response, unless Google need more details from you, however the team are still reading the feedback.
TheSanjo
Thanks David. I have sent to feedback to Google
LovelyM
Hello everyone,
@David_K, I'm grateful for your helpful response.
@TheSanjo, we appreciate you sending feedback about preventing a Google Home and Nest speaker from controlling smart devices in another room. If you have other feature requests to share, you can send them to our product team, which continuously works on improving the features on our devices.
If you have other questions in mind, let me know; otherwise, I'll be locking this thread in the next 24 hours.
Lovely
