12-12-2023 04:04 AM
I've searched the forums, found many similar complaints, but no fixes. I have automation trigger issues with a Nest Hub and 2 pixel phones on the account.
I've had trouble for months now with automations working only randomly. Sometimes it doesn't detect my phone isn't home, sometimes it does, but the automation still doesn't trigger, and then for a few times in a row it works perfectly.
It used to work all the time. Then I tried disabling the unused personal routines and that's when the trouble seemed to start. I've put it all back, tried deleting the apps, the home, clearing storage and caches, sending feedback with logs... And no fixes yet.
Can anyone help? I can't be the only one after reading the forums. Does anyone know reliable fixes that will make this problem solved?
02-08-2024 05:55 AM
Hi SchuStir,
Thanks for reaching out, and sorry for the delay. We'll work together to identify the cause of the problem and find a solution. A few questions: Are you using Android or iOS? Is the Google Home app updated? What is the distance between your Google Nest Hub and your Wi-Fi router?
Juni
02-10-2024 04:26 AM
Oh, and I use both iOS and android.
02-10-2024 05:35 AM
Thanks for the additional info you've shared. We'd be happy to take a look into this for you. Please fill out this Contact Us form with all the needed information, then let me know once done.
Juni
02-10-2024 05:44 AM
I have completed the form
02-10-2024 10:38 AM
Hello SchuStir,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Please check your inbox, as they may reach out to you via email anytime soon.
Juni
02-10-2024 04:21 AM
I’m pretty tech savvy so everything is up to date. The hub is on the beta channel. But switching didn’t make a difference. The router is less than 5m, but through some walls. It does have good signal.
we use presence sensing on 2 pixel phones. Everything has been reset, reinstalled, etc. the trouble seems to have started when I switched off the default personal routines (I never used them).
ive been on holiday for a week, and the activity shows me leaving at 6;58, but the home didn’t switch to away until 7:50. It also says a device left at 14:29, but by then I was already on my flight in airplane mode.
