Script Editor - Ambient & Temperature Setpoint Help
nestnoob3
Hi all,
Looking for some advice, simply put -
I would like to perform an action e.g. reduce the setpoint or switch off a heater, when the ambient temperature of a room is equal to or greater than the manually set setpoint of my Nest Learning Thermostat.
Google Home doesn't appear to have this functionality and the Ambient and Setpoint must be a value e.g. 17C rather than looking at the value of each other? If I want to run the heating setpoint at anything other than 17 I have to change the script every time to execute the same actions.
Any help is appreciated
nestnoob3
Thanks for your reply. I’ve managed to achieve what I need to now by creating multiple scripts for different temperatures with a 0.5 degree difference. Seems to be working well. Still exploring whether I can consolidate these into 1 script using different conditions.
2 REPLIES 2
AndersC
Hi @nestnoob3,
Thank you for posting in the community. I understand this feature may be useful, considering your needs and the needs of all Nest users.
We're always looking for ways to improve, and we appreciate your feedback.
Let me know if you have more questions.
Anders
nestnoob3
