11-06-2022 01:25 PM
Bit of an odd one this, so I’m just seeing if anyone has experienced anything similar?
I have several different sets of smart lights originally setup with various apps (Govee, Smart Life, etc) and link these to Google Home.
Now when I use the dedicated app, the colours set and change absolutely fine.
However, when I select the colour using Google Home or a Nest Hub, the colours set totally wrong. Blue is light green, that sort of thing.
It’s worse and more obvious in my lounge as I have a few lights grouped. So some lights set correct and others are a totally different colour.
Any ideas? Anyone seen anything similar?
11-11-2022 08:17 AM
Hi roblawton
Sorry to hear about the trouble. I wanted to follow up and see if I could be of any help. A few things: which brand is having issues? Were there any recent changes made before the issue started? Is this happening when you change the color using voice command?
You can reboot your mobile phone, lights, Nest speakers/display and your WiFi router to refresh both devices and WiFi signal.
Let me know how it goes.
Juni
11-14-2022 10:26 AM
@Juni, thanks for the help.
@roblawton, I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Dan
11-15-2022 10:36 AM
Dan
