Solar Panel / Magnetic mount
Sloey316
I have a nest outdoor battery camera that I connected to a solar panel. I keep getting alerts that the camera is not getting enough power because it is not correctly connected to the magnetic mount. I have reposition it several times, made sure the magnetic base is clean, and checked each time the battery and it shows it is fully charged and powered by solar. Anyone have any idea the issue?
2 Recommended AnswerS
@Sloey316
Maybe the camera is defective then.  You could try contacting Support:
@Sloey316
If you have two battery cameras that gave the same error when using the solar panel, that would seem to be a problem with the solar panel.
If you're using a solar panel, the solar panel does not directly power the camera:
"If you’ve connected your Nest Cam (battery) to the Wasserstein Solar Panel, the panel doesn’t directly power the camera. Instead, the battery is trickle charged by the panel, and the camera runs off the battery charge."
https://support.google.com/googlenest/answer/11830989
14 REPLIES 14
@Sloey316
Is the USB power cable plugged into the bottom of the camera with the cable feeding towards the FRONT of the camera (as it should)?
Is the mounting bracket correctly mounted, as shown starting at about 3:40 in the video here?
https://support.google.com/googlenest/answer/10919314
@MplsCustomer wrote:
@Sloey316
Yes and I have I have taken it down several times and checked it. I have a second camera with the same set up and no problem from that one.
@Sloey316
Sloey316
Unfortunately this is a replacement cause the original did the same. I appreciate the suggestion
@Sloey316
No it is just one of the cameras that have this issue. The second camera works fine and no issues
@Sloey316
I thought you said the original and the replacement did the same thing.
Sloey316
I have two cameras each connected to a solar panel. One I keep having this issue with and I have replaced the camera still does the same thing. The other cameras I have hooked up to a solar panel I have not had this issue with. Sorry for the confusion
@Sloey316
I am not an expert, just another Google Nest customer. But if you've now tried two cameras with the same solar panel--and you have another camera that IS working with a different solar panel--then MAYBE the problem lies with the first solar panel.
You could try connecting the replacement camera to the solar panel that is currently working with your other camera, and see if you get the same error.
Sloey316
Ok thanks for the suggestion I appreciate it
Adim
Ensure the solar panel provides consistent output, check all connections, and update the firmware to resolve the power alert issue.
Regards
Force-V
Khubaib
It sounds like you're dealing with a frustrating situation! Have you tried a factory reset after connecting the solar panel? Some users have found that this step is crucial for the camera to recognize the solar power source properly. Also, ensure that the power cable is securely connected and that the solar panel is getting enough sunlight. Keep us updated on how it goes!
Share
Rewrite
SolarPriceinfo
As solar energy gains momentum worldwide, Pakistan has seen a steady increase in demand for solar panels, especially high-capacity options like the 540-watt solar panels. These panels are favored for their ability to produce significant amounts of energy while taking up less space compared to smaller models.
ammarqaiser
That issue usually happens when the magnetic contacts don’t seat perfectly or get a thin film of dust, even if the battery shows full. Try gently cleaning the contacts and adjusting the cable angle so there’s no tension. I had a similar case when testing setups with solar batteries in Pakistan — stable power delivery made a big difference.
