Unable to add Lutron switches to my home/rooms
APhome
I recently added a Lutron dimmer in my house.  I am able to control the lights using the Lutron app.
I am able to link Lutron to Google Home, and voice control of the lights works through my Google devices.
However Lutron still appears as "Linked to you" in my devices, but not assigned to a home. I can't assign it to a room, and it's not showing up in home control options.
Pressing the icon in the Home app (under "linked to you") does not control the switch, and long pressing does not allow for me to add it to a home/room.
Not sure if I'm missing a step?
Azarco
Hey APhome,
That certainly hasn't been easy for you — let's check this out.
Was it working before? Make sure your devices are within 15-20 feet of your router and connected to the same network. Could you try reinstalling your Lutron and Google Home app? Also, try relinking your Lutron account using these steps:
  1. Open the Google Home app.
  2. Select your light > Setting > Unlink (Home Automation Partner) > Unlink.
Hope this helps.
Alex
Azarco
Hello there,
Checking back in to see if the troubleshooting shared above helps. Let us know by updating this thread and the Community will be happy to lend a hand.
Alex
Princesss
Hi APhome,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest devices and we'd be glad to assist you further.
Princess
