Using Nest Doorbell (battery) to ring at Sonos
Jravnsbaek
Moderator edit: Subject updated for clarity and findability.
I have been trying to configure Google Home to have the doorbell ring on my Sonos loudspeakers, but the case I currently have with Google support says that the batteri version doesn’t support other speakers ???
This doesn’t sound correct in my ears.
Anyone have tried to make the doorbell ring at Sonos ?
@Jravnsbaek
I don't know whether that's possible or not. This is Google Nest's Help topic on "Visitor announcements":
https://support.google.com/googlenest/answer/7672451
Lance_L
@Jravnsbaek, thanks for reaching out to the Community. I’d be happy to help you with your question. Let’s check it out.
For visitor announcements, you can use this feature on the following devices:
Let me know if you have other questions.
All the best,
Lance
Well my incident to Google support was handed over to another technician and he just responded that the battery version doesn’t support the same function as the wired version.
As of now, it is not possible to use a Google Nest battery doorbell to ring on Sonos loudspeakers. The only way to make it work is to have a wired Nest doorbell, which can be connected to any Sonos speaker using the Google Home app.
Google has not yet released a way for the Nest battery doorbell to ring on Sonos speakers. They are working on it, but there is no ETA for when they will be able to do so. ☹️
Lance_L
Hello folks,
@Jravnsbaek, I appreciate getting back to us and keeping us in the loop. Our team is working hard to deliver the best experience possible for our users. The best way to get your thoughts, feedback, and feature requests to the people who can make changes is to share feedback about Google Nest.
Lance
