Where is setting for trriger automation in preview app?
xtimex
2 months ago it was said that the new application will contain triggers for motion sensors, where is?
10 REPLIES 10
Mlabrador
Hi xtimex,
Thanks for posting in the community and apologies for the late response. Could you tell me what brand of motion sensors you are using?
Nikki
Azarco
We're sorry for the late reply. If you're referring to the Automation tab. It will contain both Personal and Household Routines for the customer. From this tab, you can quickly create, edit, and run Routines. Check this article to know more about Routines.
Alex
Dan_A
Hey xtimex,
Dan
Dan_A
Hi xtimex,
Apologies for the late reply. I'm not familiar with PIR and door sensors on how Tuya or other 3rd party devices work. I think it would be best to reach out to them to better the explanation and to gain the correct information. Also, for Tuya smart devices to be linked to your Google Home app and your Nest speakers, all must be on the same Wi-Fi network. Follow the steps below to add your Tuya smart devices:
  1. Open the Google Home app.
  2. At the top right, tap your account.
  3. Verify that the Google Account shown is the one linked to your Nest speaker or display. To switch accounts, tap another account or Add another account.
  4. Tap Assistant settings > Home control.
  5. Swipe down with your finger on the screen.
  6. There will be a spinning circle. The sync is complete when the circle disappears.
  7. Check for your device in the Home control list.
Also, check out this guide about how to control your smart devices.
Keep us posted.
Dan
Dan_A
Dan
xtimex
No, I found where is settings, tnx.
Dan_A
Awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread in 24 hours unless I can help out with anything else.
Dan
xtimex
By the way, do you know why you can't use PIR sensors and door sensors from Tuya when creating automation? I can connect and see them in the google home application, but I can't use them when creating routines?
