08-10-2023 02:47 AM
I had my nest doorbell (battery) working just fine then changed my WiFi.
Could not get the WiFi area found to change it on the doorbell. Changed everything else on other things
Accidentally removed the doorbell from Home app
Doorbell works if on door ... Ie showing light and can hear at door the bell
Will not show light if taken off door to recharge and won't reset at all. There's nothing! I can't get it back. Put back on door and you can see it working and hear it outside. Obviously cannot hear it indoors now and no doorbell on app
So it's working... Sort of
Why won't it reset so i can change it's WiFi and reattach it to home?
08-10-2023 09:37 AM
I have seen a few posts in this forum from customers whose camera or doorbell simply would not perform a factory reset, and have gotten replacements.
You could try contacting Support, using the link and instructions in this post in this forum:
08-10-2023 08:52 AM
It seems that many customers have trouble successfully performing a factory reset. Some seem to have more success if they hold down the factory reset pin for longer than 12 seconds. Perhaps it's because it's difficult to actually depress the reset pin.
08-10-2023 09:32 AM
I have tried everything.. pins, phone pins, drawing pins, 12 secs, 20 secs, 30 secs... Putting it in at different angles. It won't reset! This was expensive and works, but i cannot connect it
08-10-2023 09:37 AM
08-13-2023 12:01 PM
Hello IfAbbie,
Checking in — did you get a chance to try the steps shared by MplsCustomer? If so, how did it go? Let me know if you need more help.
Edmond
08-13-2023 12:10 PM
It is not working. I have over £100 doorbell I can do nothing with.
08-13-2023 12:37 PM
Have you tried contacting Support?
08-13-2023 01:12 PM
I just tried again and I seem to pick times they are not about
I will try again tomorrow
I am adding what I am saying here so I do not lose it
No reset. I lost it from home after I changed wifi and am trying to reset it to factory to go again. It will not light up when I plug a charge in, it will not reset. However, when I put it on the door it is still ringing if pressed and lighting up.
So I need to reset.
I have tried everything. Different pointy things, different lengths of time with each.
NOTHING
£170 for something that no longer works. I am not happy
08-14-2023 01:49 PM
Thanks for trying. Checking in to see if you are able to contact our support again. Let me know if you have additional questions.
Edmond
08-16-2023 02:13 PM
I just wanted to follow up and see if you still need any help. Let me know if you have any additional questions from here.
Edmond
