problem with my chromecast
marganim
6 REPLIES 6
marganim
my chromecast is stuck in this screen, and how can i remove it, i dont want to go further because my google home app have a problem, i want it back to the previus screen like you just turn on your tv
Juni
Hi marganim,
Good question, let me help you. This screen is an indication that you need to set up your Chromecast again. Could you tell me what problem you are experiencing on your Google Home app? Also, what Chromecast model are we working with? Check the steps below on how to set up your Chromecast.
  1. Plug in your Chromecast.
  2. Download the Google Home app on your Chromecast-supported Android device.
  3. Open the Google Home app Google Home app.
  4. Follow the steps.
    • If you don’t find the steps to set up your Chromecast:
      1. At the top left of the Google Home app home screen, tap Add Set up device New device.
      2. Follow the remaining steps.
  5. Setup is successful. You're all done!
Check this link for more information.
Juni
marganim
thank you for your answer mr juni, i've tried that steps for several times and the problem on my google home is "local network", i dont know what's wrong beside that because when i check in my setting, i cant find the problem with my local network, i've already installing and uninstalling the app for many times, and the results is the same, my model is google chromecast 3.
thank you mr juni, im certainly waiting for your helping answers
Azarco
That certainly hasn't been easy for you, were there any recent changes or updates to your network or set up? Give these additional steps a try:
  • Check the Wi-Fi settings of the phone and connect directly to the Chromecast's temporary hotspot, Chromecast XXXX, or manually look for the previous name that has been used for the Chromecast device like Living Room TV or Bedroom TV, and then proceed with the normal setup.
  • Reboot your Chromecast and router to refresh the connection.
  • Reinstall your Google Home app.
  • Factory reset the Chromecast.
  • If the issue persists, try using a different mobile phone to see if you'll get the same result.
Alex
Azarco
Hello marganim,
Checking back in to see if the troubleshooting shared above helps. Let us know by updating this thread and the Community will be happy to lend a hand.
Alex
Azarco
One quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need assistance, feel free to start a new thread in the Community and we’ll be happy to help.
Alex
