2 pipe fan coil system
Kylep2122
Greetings, looking to transition from an analog thermostat on a 2 pipe fan coil system with high/low fan settings and wondering how to wire in the nest thermostat since I don't have a previous digital system to mimic. C-wire would be installed. Picture of the schematic for reference.
Looking at the schematic you provided, I would say your system is using line voltage which is not compatible with any of the Nest thermostats in America/Canada.
Let me know if I am wrong about the voltage.
No, you're correct and I realized line voltage would be an issue after doing some more digging following my post. A relay could be an option, but not sure if an individual relay would be needed accommodate each fan settings.
Ryan_G
It looks like we haven't heard back from anyone and I'm going to lock the thread. If you have any further questions or concerns, feel free to create a new thread and we'll be glad to assist you.
Thanks for your help, Brad.
Have a great day.
Ryan
Just checking in to see how the conversation is going as there's been a lapse in activity on this thread. Thank you, @Patrick_Caezza for all of your help!
Best regard,
