3 Nest temperature sensors disconnected and wont reconnect to thermostat
Bnaq887
This morning I had a notification on my phone that all 3 temp sensors were disconnected. When I go the list in the app and tap on anyone of them it opens up the troubleshooting webpage.
I have done the following:
1. Restarted Nest Learning Thermostat
2. Removed the battery from one of the sensors and tried to reconnect. Didn't work!
3. Removed one sensor from the list and wanted to add back but that's not working either.
I now have 3 sensors, 2 previously connected and not working and 1 not able to connect since I reset it. The only thermostat working is the Nest Learning thermostat itself. Please help. Thanks
Ryan_G
Hope this helps!
Kind regards,
Ryan
