12-27-2022 05:55 PM
My 3rd Gen Learning Thermostat began having low battery and loss of connectivity several weeks ago. After charging for several hours using the USB cord, it works normally until a few days later when the battery is again low, the system won't connect to the internet and I must repeat the charging process. With this last experience, I have before and after ~1 hour charge time:
Before: battery 3.64V, Win 37.29V, and lin 20mA.
After: battery 3.768V, Vin36.39, and lin40mA
My wire connections: Y1 cool, G fan, W1 heat, and RH power.
Any thoughts besides having to charge every other day? When disconnected, the house temp drops quite quickly in this bad weather. repeated charging can't be the only solution, right?
12-28-2022 05:15 PM
Started to have the same problem as of two days ago.
Any advice will be appreciated
Ps.
Had the unit working for 2 months before the problem started, I have 5 in the house and switching the unit to a different location have not effect
01-02-2023 06:41 PM
@HollyK, thanks for sharing the steps that worked for you. Please observe it for now and let us know if anything comes up.
@Caru501, I'm sorry to hear that you're having an issue with your Nest Thermostat. I'd love to know more about this and I have a few questions:
Edward
01-03-2023 07:43 AM
Hi, thanks for following up on my post, my unit is gen 3 learning thermostat and I'm only using 2 wires.
Call customer service and a replacement is on the way.
I actually have 5 thermostat and after trying to figure out what was the problem I decided to replace the unit with the problem with one on the room next to it and see if the problem persist.
Hold and behold the unit that was working just fine in the other room was just fine in the location that was given the battery drain issue and the one that had the problem still had the power drain no matter where in the house it was installed.
a month ago
Hi Caru501,
Thanks for the update. I'm glad to hear that you were able to get a replacement. Let us know once you receive it. Keep us posted.
Edward
3 weeks ago
Hi Caru501,
Edward
01-01-2023 04:24 PM
Well, after lots of internet detective work, I learned that you can purchase a~$30 nest power adapter (from google or amazon for same price/faster delivery) and quickly install so that the system behaves as though there's a C wire. It was simple to install - took about 10 minutes. Will see if that does truly fix the problem, but I am optimistic.
3 weeks ago
3 weeks ago
Please don't lock the thread. I'm not convinced this is resolved. I've had to charge the unit 2 more times. The first was immediately after the installation of the power adaptor, so I was giving it time and being patient but I had to charge again about 72 hours ago. I am tracking it now to see how long before it is again depleted. Regardless, it seems as though there's a problem and this is a defective unit. I'd like to hear your thoughts.....
Holly
3 weeks ago
Hi HollyK,
Thanks for the update. Could you share the power readings of your Nest Thermostat? You can find this by going to your Nest Thermostat's Settings > Technical Info > Power.
Edward
3 weeks ago
Thanks for your patience - I was traveling. Just under a week since last charging with the USB, it is again low battery. Current readings are:
Battery: 3.650V
Voc: 33/53
Vin: 32.51
lin: 20mA
Surely this signals that my thermostat is faulty. I think I've done my part to ensure that there's nothing on my end. What are the next steps?
Thanks
Holly
3 weeks ago
Hello folks,
Thanks for helping here, Edward.
@HollyK, Thanks for letting us know the status. I'm sorry to hear the issue still persists, and we appreciate you trying to have it manually charged just to have a heater at home. We'd be happy to take a look into this for you.
Please fill out this form with the needed information and let us know once you're done.
2 weeks ago
Hi HollyK,
I'm checking back in — how's it going? Have you had a chance to fill out the form? Let us know so we can assist you right away.
2 weeks ago
Hi HollyK,
Edward
a week ago
Hi HollyK,
Edward
