3 weeks ago
If True Radiant is On, then heating doesn't work. The room temperature is far away from the set point. If I set True Radiant to Off, then heating works fine. I use a Heatlink and a Viessmann Vitodens 111-W boiler. The configuration is in-floor heating and a combi boiler controlled by the OpenTherm protocol.
2 weeks ago
Hi MieszkoChmiel,
Thanks for posting in the community.
I understand that you've determined that your Nest Learning Thermostat 3rd gen, connected via Heat Link and OpenTherm to your Viessmann Vitodens 111-W boiler (for in-floor heating), fails to initiate a heating cycle when the True Radiant feature is enabled. I'm glad to help you with this concern.
With True Radiant, your Nest Thermostat learns how long your radiant system takes to heat up your home. It’ll turn the heat on early to reach the scheduled temperature, then turn it off early so your home won’t heat over the temperature you want.
True Radiant automatically adjusts when the system turns on and off. There’s no need to guess how early you need to turn on the heat to get the temperature you want when you want it.
For example, the Nest thermostat might learn that to reach 21.5ºC, it should turn the system off when the room hits 19ºC because the already hot radiators will take your home the rest of the way to 21.5ºC. The Nest thermostat will also maintain that temperature by turning your system back on before the temperature gets too low. To learn more you please check this Google Nest Help Center article: True Radian.
After considering the previous information I recommend you to check the following facts:
If you have any other questions about Google Nest products or need more help with anything else, just let me know.
Virna
Sunday
Hi @virnab,
thank you for the feedback. I checked the facts as below but my problem is not solved.
Please also note that I use the following additional settings Auto-Schedule: No, Home/Away Assist: Stop Using. Please help me to solve the defect.
BR,
Mieszko
