4 wire heat pump fan issue
Waynejo
Replacing old thermostat with new Nest 2020. 4 wire system, Rheem heat pump. Working system but when I installed the nest the blower dan would not function. I used the G wire as a common, compressor came on but no fan?? Reinstalled old thermostat, works fine.
Post a picture of the original thermostat's wiring.
If you don't have a C wire, then use the Google Nest Power Connector. The G wire trick never works correctly and you lose fan control.
Ryan_G
Hey Waynejo,
I just wanted to follow up and see if you're still in need of help? Please let us know, as we would be happy to answer any questions you may have.
Thanks for helping us, Patrick_Caezza.
Ryan
Ryan_G
Hope this helps!
Kind regards,
Ryan
