AC/Heat keeps going off and on before desired temperature is reached??
KR1
AC/Heat keeps going off and on before desired temperature is reached?? Then it counts down from 2 minutes before it turns back on…only stays on about 1 minutes and continually repeats this cycle. Had to turn heat to emergency heat to get it to stay on…
Is this a newly installed Nest Thermostat or one that was working correctly before? If is newly installed can you post a picture of the original thermostat's wiring here?
Which Nest Thermsoatat do you have?
EdwardT
@Patrick_Caezza, thanks for the help!
@KR1, how's it going with your Nest Thermostat? Still need our help?
Edward
EdwardT
Hi KR1,
Edward
EdwardT
Hi KR1,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
