Ac blowing hot air in cool setting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
08-29-2023 10:09 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-29-2023 10:13 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2023 08:41 AM - edited 09-03-2023 05:31 PM
Hi Malek3,
Thanks for posting here in the Community forum, and I'm sorry to hear about the situation. I want to check if you are still in need of any help. If so, please answer the following:
- Where are you located? From North America or Europe?
- Did you try using the Help Center or troubleshooter before contacting support? If so, which steps have you tried already?
- What is the make and model of the cooling and heating system, including the make and model for the, fan-coil or air-handler units?
- Does your HVAC system use a multi-speed or variable speed fan?
- Did you verify if Fan and Heating still work?
- Did you turn off the power to your HVAC system?
- Are the breakers turned on?
- Did you recently experience a brownout or blackout?
- Did you have any construction or maintenance work done on your home?
- Do you see any power code on your thermostat?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2023 11:57 AM
Hi Zoe,
I am located in North America California Los Angeles.
i live in a apartment building.
i have discounted the the C
and connected the cable I had in W to OB
now the AC works fine I just lost the connection internet via the nest thermostat.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-03-2023 05:45 PM
Thanks for the follow-up information, and I'm glad to hear that it has been sorted out. In this case, we could tell that you have a heat pump system instead of a conventional system. On the other hand, if you've lost your internet connection on your Nest app, kindly follow these steps:
- Go to Settings > Reset > Account Connection.
- If you've already set up the thermostat on the Nest app, kindly remove the thermostat from the app first before you set up its internet connection again.
- If not yet, just go to Settings > Network to select your WiFi network name and connect it again.
Let us know if you have any other questions. We're happy to help.
