10-03-2021 07:06 PM
When I try to adjust temperature manually with the ring, I get no response from thermostat. I have to adjust temperature with my phone app. How can I use the ring around the thermostat?
10-03-2021 08:53 PM
Sounds like the UI is frozen but the back end is still working, try a normal restart first, and if that does not work, a factory reset may be in order( but let's keep fingers crossed it just needs to be restarted )
10-03-2021 08:53 PM
10-04-2021 06:42 AM
Thanks for your suggestion. That seems to have solved the issue although I restarted it first manually and that didn't worked. Then I went into the settings and restarted it from there and it fixed the issue for now. Thanks for your help.
10-07-2021 01:49 PM
It looks like we have come to a solution so I'm going to be locking this thread. If you have any other concerns or questions, please feel free to create a new thread.
Have a great day.
Garrett DS
