12-01-2024 12:31 AM
Some general info:
I've checked the voltage the Heat Link supplies over the T1 and T2 lines, it's 11.86V. Is that enough? I'm guessing either the battery is not okay anymore, or the Heat Link does not provide enough power anymore.
I've tried to contact Google with the form, but it says "Please try again during support hours." - which are from 12 a.m. - 11:59 p.m., each day; what am I missing?
12-04-2024 11:31 PM
Hello @NicksNest!
Thanks for bringing this to our attention and posting it in the community. I’m really sorry to hear about the inconvenience you're experiencing with your Nest Thermostat’s battery.
Before troubleshooting, I’d like to confirm a few things:
Once we have this information, we can diagnose the issue and provide a solution.
Thank you,
Catheryn
12-06-2024 03:23 AM
Hi Catheryn,
Thanks for your response. My answers:
1. About 10 days ago
2. Yes it is, only the thermostat dial has the issue.
3. It is very securely seated.
4. They were. Currently I've disconnected them and replaced them with a (temporary) USB cable to keep it on/(semi-)charged.
I got in contact with someone from Google customer service, who couldn't do anything because out of warranty.
It won't charge past 3.9V, whereas 3.7V lithium batteries normally charge to about 4.2V maximum. So I suspect the battery is the culprit and doesn't hold enough charge from the 12V supply in the Heat Link. Or that supply might not be sufficient (anymore).
