01-27-2023 09:36 AM
I am trying to connect the Nest Thermostat. Current thermostat is a Honeywell. See picture. Wondering if the B wire is actually the C common wire.
02-02-2023 07:29 AM
Hello hauser775,
Thanks for reaching out about your systems' compatibility with the Nest Thermostats. I'd be happy to take a look at this for you.
It appears that your heat pump system wiring setup is compatible. The blue wire would be your 24 V common. So, you should connect it to the C terminal for the Nest Thermostat. Also, please follow these guides for your wiring configuration so you have a reference:
Let me know if you need more help.
02-05-2023 12:33 PM
02-09-2023 01:10 PM
Hi hauser775,
I'm checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
