08-31-2021 09:58 AM
Original Poster: BuffaloBeerCrosby
Goodman non-communicating air handler, everything works perfectly. Heating, cooling, dehumidification all work perfectly and my bills are significantly lower even though we turn down to 64°F to sleep. Very happy with this setup except one thing:
01-28-2022 08:43 AM
i have the same problem - did you find a fix?
hvac guy came out and had me jumper the res (power) and green to test and the did turn on the fan, so he said that the Nest is the prob and that “they’ve seen that before,” with no more explanation. i’m wondering if the nest is internally jumping the C wire to G instead of RW, and that hopefully that’s just a “pro” setup setting change…?
