09-16-2021 06:14 AM
I have tried charging with usb cable overnight but only stays charged for a couple of hours. I don't know what the reading a above mean.
09-17-2021 04:45 PM - edited 09-17-2021 04:47 PM
The display shows your battery level at 3.423 volts. That is too low for proper operation of thermostat. 3.6 is minimum to operate, 3.7 is minimum for software update. Should run between 3.8 - 3.9 volts. There are a lot of recent comments about Nest E no longer charging properly. The other voltage / amperage readings are in the normal range.
10-05-2021 03:10 PM
Hey jheileson,
I wanted to follow up, and see if you are still in need of any help with the thermostat battery. Please let me know, if you are still showing a lower voltage on your device.
Thanks so much endicott65 for the helpful information as well.
10-08-2021 03:20 PM
Have a great day.
Garrett DS
10-12-2021 09:25 AM
Have a great day,
Garrett DS
