10-17-2022 11:37 AM - edited 10-17-2022 11:52 AM
Hello. I just installed a new Nest e Learning thermostat and my system is compatible based on my previous thermostat and settings. I have a heat pump (I think since I do not have natural gas and HVAC is one system outside my home). When I turn on cooling, hot air comes out of the vents, cool on the heat setting. I found support instructions to change heat pump setting but I do not have o/b wires. I also do not have heat pump as an option for my equipment so I selected forced air (which is I think what I have). I have attached pics of my old Honeywell thermostat and the current set up. I checked and my thermostat is fully charged. Any ideas to get it to work?
Thank you for the help.
10-17-2022 05:18 PM
Problem solved. Since I have a heat pump, my HVAC friend said to move the white to o/b. My home is cooling now!!!
10-22-2022 11:04 AM
Hi Dkenney,
Thanks for posting. I'm glad to hear that you were able to figure it out. Please observe it for now and let us know if anything comes up.
Edward
10-17-2022 05:18 PM
10-22-2022 11:04 AM
Hi Dkenney,
Edward
10-25-2022 02:58 PM
Hi Dkenney,
Edward
10-26-2022 03:25 PM
Hi Dkenney,
Edward
10-26-2022 03:27 PM
Have already applied that my problem is solved.
10-27-2022 03:39 PM
Hi Dkenney,
Thanks for the update. I will be locking this thread now. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
