Compatibility with Bosch heat pump
human156
Why won't Google redesign the nest thermostat so that it works properly with a Bosch variable speed heat pump?
6 REPLIES 6
Each manufacturer uses proprietary communications with the various advanced systems, so would be almost impossible to program a nest thermostat to communicate with those very advanced systems that the manufacturers produce using proprietary thermostats. Some manufacturers who have advanced systems like that also provide a control board that can be used with old conventional system so you have to tell me the model number of the Bosch system you have so I can look it up for you and see if it has a control board for conventional hook ups using a thermostat like nest
AC Cooling Wizard
Installer Kendrick Heating and Air
Product category Air­to­Air Heat Pump
Name of product BOVA60HDN1M20G
Serialnumber 399A­279­000109­8733952438
Installation date 6/7/2023
Registration date 5/31/2024
@human156 ,
A product code of BOVA an Bosch Outdoor Inverter based 4 to 5 ton Heat Pump and it uses a conventional HVAC wiring which is fully compatible with the Nest Learning Thermostat as long as the Indoor unit is a Bosch BVA series i.e. BVA60WN1. The indoor unit can support up to 3Heat and 2 Cooling thermostat.
AC Cooling Wizard
What is the wiring ? The app tells me that it is not compatible.. ita a Bosch BVA36WN1-M15
I also have 7 wires.
  • C blue
  • O orange
  • W/E black
  • W2 white
  • R red
  • G green
  • Y yellow
@Backwoodsmen,
I would need to see the old thermostat and which color conductor is attached to which terminal.
AC Cooling Wizard
