11-05-2021 06:02 PM - edited 11-05-2021 06:04 PM
Are there any temperature sensors on the market that can be connected directly to the hub without having to use thermostat ? I have AC in a few rooms and all automation set I just need for the task to get temperature from a sensor, was wondering if that's an option with nest hub or I need a different hub/solution for it.
Cheers
01-07-2022 12:43 PM
Hey grzegd,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
01-07-2022 11:01 PM
Hi, yes I still haven't found s solution.
