Connection thermostat to heat link
Anis-Hamdoun
Morning my  nest learning Thermostat 3rd gen  can't connect heat link while light indicator is Blue
9 REPLIES 9
AlexD
Thanks for reaching out here @Anis-Hamdoun . I would be happy to try and assist.
Could you first let me know if this is the first time it is being installed and setup or was it working for some time and then it disconnected. If the latter, how long has it been working as expected before you first noticed this behavior?
It was working correctly until i have made a factory rest when i change my House
LarisaL
Hi @Anis-Hamdoun! Could you please go on your thermostat to Settings > Technical Info > Power and let me know the power readings for battery, Vusb, Vin, Iin?
Many thanks, Larisa.
Batterie 3,767v
Vusb 5,10 v
Vin 0,00 v
Lin 200 mA (c)
Thank you very much
LarisaL
I see. In this situation the battery level is a bit low. Could you please take the display off the base and let it charge directly from a power socket via an micro-USB cable for 90 minutes and then try to connect it again?
Let me know how it goes.
Same thing but the value of vin : 0.00 v is normal ?
TudorL
That's alright, considering the fact that the thermostat display is charged via USB. Did you manage to complete the step that my colleague sent to you?
AlexD
Hi, I wanted to check in. Did you see my colleague's message? Make sure to let me know.
OannaCG
Hey there, since we haven't heard from you for a couple of days, we'll close this thread for now. If you still need help, let us know so we can continue. Thanks!
